Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-18-2004, 06:53 PM   #1
powerguy's Avatar
Repair 1/2" scratch in paint/clearcoat - Advice
Looking at donzi with the basf diamond base coat/clear coat paint and there is a scratch about 1/2 inch wide and about 10" long. It was touched up but needs to be redone. Are there any issues I should be aware of with this paint.
Also around the fuel vent there is staining that also needs to be addressed.
What is the best wat to clean thes up so it will look like it was never damaged or stained?
As always thank you for your advice.
powerguy is offline   Reply With Quote
Old 01-18-2004, 07:01 PM   #2
H2Xmark's Avatar
1997 Fountain 35 Lightning
if you want it to look like new you will most likely need someone good at color matching and blending paint, the stain area you might try to use a wax/restorer are a light compound on this
H2Xmark is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Loto skeg repair/paint eeasy Fiberglass and Paint 4 09-20-2006 10:44 PM
custom paint and hull repair in fl. eliminatethis Fiberglass and Paint 1 07-25-2006 10:03 PM
Gelcoat scratch repair Rage Fiberglass and Paint 0 06-29-2006 05:23 PM
Advice on bulkhead repair fruitta55 Banana Boat 12 07-24-2005 09:59 AM
ColorAll auto paint repair glassdave General Boating Discussion 4 01-08-2003 05:23 PM
Search Engine Optimization by vBSEO 3.2.0
