Reversion
Old 02-25-2004, 09:57 PM
Ric232
Originally posted by outlawinil
Is the silent choice part of the reversion problem? Meaning is water more likely drawn in thru the prop.
Yes and no. Silent Choice is part of the problem, but you will not draw water through the prop hub. The problem is that when you have Silent Choice, you usually have risers that dump water into the exhaust stream sooner, thus increasing the potential for reversion.
TomR, can you get a photo of the risers showing where the Silent Choice diverters hook up? Merc may have used a different setup on the HP motors.
Old 02-25-2004, 10:02 PM
Ric232
Originally posted by hpscarab22
hey ric232, does it matter which cmi's such as etops or sport tubes??? speaking of 232 baja's got a 2002 232 with 496ho has anyone put a whipple on one? very tight engine compartment(as far as in front of the crankshaft pulley). thanks
No, both will work great, and the e-tops are much less expensive.
You need 2.75" in front of your crank pulley for a Whipple. Have you measured?
What prop are you running on your 232 and what is your best speed on GPS?
Old 02-25-2004, 11:35 PM
hey ric232, we added the whipple stage 2 computer upgrade, and crane gold roller rockers, also did some porting and clean up on intake manifold, with port matching of the heads. running a labbed 23p mirage plus from houston prop. at 5300rpm, our best gps was 73. got about 1.75" in front of pulley, but should be able to modify for more. heard from anyone running a whipple on a 496ho? likes or dislikes??
hpscarab22 is offline
Old 02-26-2004, 07:26 AM
bj502's Avatar
I'm running a '95 502 EFI Mag with aftermarket Gill, SS risers into Corsa silent choice. Thinking of putting big valved iron heads and a roller Cam in this season. What would be a good cam choice?
bj502 is offline
Old 02-26-2004, 10:31 AM
I could get a photo tonight. The risers are long, they meet the silent choice right at the transom. The silent choice is shaped like an "S" to feed back into the "Y" pipe.
I was thinking of adding overboard dumps and letting some of the water out before the end of the riser pipe. The end of the pipe only has four holes that are maybe 3/8 in diameter.
TomR is offline
djtalon
12
10-20-2006 09:47 PM
MS 28 SCARAB
10
04-27-2004 11:47 AM
Quaid
13
01-02-2004 10:20 AM
jhnrckr
3
10-15-2003 01:40 PM
Lazze
18
10-07-2002 11:50 AM
Quick Reply: Reversion
