x-dim
there is a brand new blackhawk drive on ebay, search # 2466095435, also contact xs marine ,they were cutting down bravos, email [email protected] ask for allan
I don't know what kind of boat you have,
but I would think twice before I bought a Black hawk.
If your boat is a V-hull 21-28'
I would go whith mcollinstn (post#4).
When you cut the transom, mine is 2 peices, 1" thick plywood glued by fiberglass in between and on the front and back with gellcoat on the outside. do you cut out a larger square on the inside 1" slabe say like 1 1/2 by 1 1/2 foot, then a smaller 1' by 1' on the outside slab? then glue those together and fiberglass up and regellcoat the outside? Or how is this done ?
Team Dysfunctional
I would stay away from the black hawk drive just because of the availability of parts, Props , and people that are familiar with them.
what about surface drives like a Kamma or a arrneson??
There is someone who makes a surface drive that will adapt to a bravo housing.
If it aint broke .... I can break it....
