Hynautic steering by Teleflex??? >
Old 03-17-2004, 11:20 AM
Charter Member #655
dyno's Avatar
So nobody has told me what fails when a stock set-up breaks?????
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 03-17-2004, 11:29 AM
Dont bother with the internal. Not much advantage. With the extremely weak gimbal and ring on the bravo, external is the only way to go.
I also agree with birddog, go full hydraulic. Especially if your current cable setup is worn.
As for what fails, cables helm, connections, etc all loosen up. Then there's the upper swivel pin/gimbal ring.
Gary
Gary Anderson is offline
Old 03-17-2004, 11:30 AM
Charter Member #655
dyno's Avatar
So I have to spend 4k to do it right.....Bummer!guess I'll cheat death again this summer.
dyno is offline
Old 03-17-2004, 11:32 AM
birdog's Avatar
I told you what failed on mine...Helm unit....stripped the gears..also..what Gary said
birdog is offline
Old 03-17-2004, 11:34 AM
birdog's Avatar
Sooo....The Hynautic system has no external rams ?
If so...Dont waste your grand..Get the real deal !!
birdog is offline
Old 03-17-2004, 11:46 AM
Official OSO boat whore
Dyno-just how fast are you running? I really don't think you are fast enough to justify a full hydraulic system.
Cord is offline
Old 03-17-2004, 11:48 AM
Charter Member #655
dyno's Avatar
well cord that depends on who you talk to, I say I'm too slow my wife says I'm too fast! 75......
dyno is offline
Old 03-17-2004, 11:50 AM
Charter Member #655
dyno's Avatar
Gary I see on other posts that you have built your own set-up on several occasions...you need to make a set of prints and sell them with the part #'s to build one I'd pay for the the advice...
dyno is offline
Old 03-17-2004, 11:51 AM
I assume the hydraulic you're referring to is an internal, non-power assisted system.
Birddog, hynautic does make an external ram, called K-5. They've been around a long time and as I stated above, are very strong.
Dyno, if you're going manual, buy a hynautic helm made for the K-5 or similar sized rams. I think I've even got my old one lying in the basement. Find a couple of used K-5 rams (used price is typically $100-125 each) rebuild them, buy a reservior/pressure regulator, and hoses. You can have a twin ram, manual, external hydraulic setup for about the same money.
Gary
Old 03-17-2004, 11:56 AM
Charter Member #655
dyno's Avatar
Gary want to sell that helm? where can I buy used rams?
dyno is offline
Quick Reply: Hynautic steering by Teleflex???
