Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-18-2004, 02:21 PM   #1
Nordicflame's Avatar
2002 Nordic Flame Twin 588s
What oil do you use for your initial start up on a new motor?
I have been told to use a non detergent 30 weight such as Valvoline 265 for the initial trailer or dyno run for the first ½ hour under light load. This supposedly helps with ring seating. Then change to a heavier race oil for initial, loaded break in on the water or dyno.
After break in change it again to your favorite synthetic such as Amsoil 20-50 Racing.
What’s your preferences?
Dave
Nordicflame is offline   Reply With Quote
Old 03-18-2004, 03:16 PM   #2
Charter Member #71
DanB's Avatar
1993 Cig
The cheapest 10w30 you can find. Run it a 1/2 hr, drain it, more cheap stuff, 1/2 hr drain it and change filter, then put in the good stuff
DanB is offline   Reply With Quote
Sponsored Links
Old 03-18-2004, 03:30 PM   #3
aero-offshore's Avatar
AERO,OFFSHORE
Non detergent straight 30 weight
aero-offshore is offline   Reply With Quote
Old 03-18-2004, 03:35 PM   #4
cstraub69@comcast
Straight 30 WT. Low detergent allow for better breakin. If this is a hyd. roller or mech. roller. After breakin you can go to synthetic. If flat tappet. Need to run a quality Petrolium based oil on the dyno and in the boat for about 25 to 50 hours. Then go to synthetic.
Chris
Old 03-18-2004, 03:35 PM   #5
Reed Jensen's Avatar
Fish oil from tuna cans.... hell... everyone has different opinions... chrome rings... iron rings.... synthetic... mineral... arrrrghhhh!
Reed Jensen is offline   Reply With Quote
Old 03-18-2004, 03:37 PM   #6
Charter Member #655
dyno's Avatar
1993 Sonic 31ss
what Dan said....
If your boat has a sail do you ride a horse to the ramp?
dyno is offline   Reply With Quote
Old 03-18-2004, 04:11 PM   #7
Maybe I should have made this a poll
It at least seems to be a unanimous choice to use non-detergent for initial running
Old 03-18-2004, 06:06 PM   #8
blue thunder's Avatar
330 Carver 30' Scarab Panther 17' ProV Lund
I do exactly what dan said...
BT
blue thunder is offline   Reply With Quote
Old 03-18-2004, 08:13 PM   #9
Crazyhorse's Avatar
38 Cigarette flat-deck
I do the same thing the guys with the slant 6 Dodge motor do, that they spray down with a waterhose with the oil pan off,,,,,,,,,,
Crazyhorse is offline   Reply With Quote
Old 03-18-2004, 09:09 PM   #10
Lycoming recomends .... ok guys... hold onto your hats... 100 w non detergent oil for the first 25 hours of use.... I don't think I want to be flying in an airplane with 100 w oil trying to circulate in the engine..but that is what my pilot buddy says they recomend for break-in. Scary....
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
motor will not start tahoeguy318 General Q & A 4 05-24-2005 02:53 AM
Initial Start-up on hose convincor General Q & A 6 06-16-2003 07:35 PM
gas quality for initial start up? THRILLSEEKER General Q & A 4 05-31-2003 10:17 AM
ignition timing for initial start up? THRILLSEEKER General Q & A 1 05-31-2003 01:30 AM
Search Engine Optimization by vBSEO 3.2.0
