Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-21-2004, 10:50 PM   #1
Danny_Ocean
Now where to drain trans cooler line?
Previously had log-style manifolds ('82/330/TRS/raw-water cooling, thru-hull exhaust) and just purchased a set of center-rise manifolds (GLM from MoorePerformance...quality seems high). My transmission (MercTransII) has one cooling line (in) from the oil cooler and one line out (connected to small pipe fitting on starboard riser). New risers do not have this provision. Where can I send the cooling water flow from the trans? I believe I can "t" into the main riser water fitting, but not sure if that's OK.
Many thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 03-22-2004, 07:53 AM   #2
650 NOPPER/SUTPHEN
marinetrans's Avatar
1991 SUTPHEN 26
Put a water dump out the transom or side of boat.Just did a Magnum Marine over, used Stainless Marine manifolds and sent the cooling water for the MercTrans. out thru water dump in the side of the boat. It looks cool too.
www.noppermarine.com
marinetrans is offline   Reply With Quote
Sponsored Links
Old 03-22-2004, 08:36 AM   #3
Danny_Ocean
That'll work. I've got an extra hole....in my boat.
D. Ocean
Pompano Beach, FLA
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Engine oil / trans cooler????????/ turbo2256b General Q & A 2 08-09-2008 01:14 PM
TRS oil cooler line fittings... Full Force General Q & A 4 07-18-2008 11:00 PM
Add an extra aux trans cooler? handfulz28 Trucks, Trailers and Transportation 7 07-19-2007 06:11 PM
Can a MercII trans be replaced with a velvet drive trans??? Wally General Q & A 6 06-27-2006 09:22 AM
Search Engine Optimization by vBSEO 3.2.0
