bildge cleanup >
bildge cleanup
bildge cleanup
Old 03-26-2004, 02:38 PM
Superclean or simplegreen little water and a bag of ice or 2 to use as scrubbing power. when melted drain out
JPD Motorsports is offline
Old 03-26-2004, 09:24 PM
homan
If you have anything painted with a spray can in there be careful the purple stuff will take the paint off.
Old 03-27-2004, 10:52 AM
2112's Avatar
Talking
Originally posted by Reed Jensen
after using only Soilove and water....
WOW, Did the soilove clean off the intake and hoses too?
2112 is offline
Old 03-27-2004, 10:54 AM
2112's Avatar
Jokes aside;
Do you get Soilove at the grocery store?
2112 is offline
Old 03-27-2004, 03:53 PM
Rob
Strip Poker 388's Avatar
Becarefull with the superclean. it will bleach (spot) the blue anodize fittings , Its strong stuff
Strip Poker 388 is offline
Old 03-27-2004, 06:00 PM
Havasu Cig's Avatar
I will second that. It left spots on the pulleys on my 500's.
I now use simple green in a sprayer used for spraying weed killer. I dilute it down with water about 50/50 and spray the entire bilge. For getting under the motors I use a duster on a pole used for cleaning ceiling fans in houses. The pole is plastic and flexible and you can get into all the tight spots. You can buy the dusters at Home Depot for a few bucks.
Havasu Cig is offline
Old 03-27-2004, 11:52 PM
Reed Jensen's Avatar
Originally posted by 2112
Jokes aside;
Yes... I"ve seen it at grocery stores... but at a higher price... I didn't use any solvent on the engines... just the laundry pretreater...
Reed Jensen is offline
Old 03-27-2004, 11:55 PM
No... I had to remove the intakes and hoses... does anyone recognize what brand or make motor it is?.....
Old 03-28-2004, 04:15 AM
38KV's Avatar
Looks like a 3.8 or 4.2 litre Jaguar.
38KV is offline
Old 03-28-2004, 04:27 PM
cuda's Avatar
After blowing my transmission line, we had an oily mess in the bilge. We used Greased Lightning and hot water, I couldn't believe how clean it came. I think the hot water was the key. I disconnected the hot water to the washer and connected a hose there.
cuda is offline
Quick Reply: bildge cleanup
