ssm-v & bulldog500 >
ssm-v & bulldog500
ssm-v & bulldog500
Old 03-28-2004, 01:53 PM
Question ssm-v & bulldog500
I just got ,here in Brazil,a pair of ssm-v drives and have some questions: they were mounted since new ,inverted for about 150hours( left drive mounted to starboard and vice-versa).Could this be a problem for fadigue reasons?I just finished a new design /hull , two step ,40 feet long, 8000# displ. and will be installing the drives ,so any help for " X" measurements for this tipe of drives ( only four in Brazil ).the drive's ratio upper/lower is 1.5:1 total and I have a pair of Rolla"s stainless 4 blade 16.25 x 22 ( would it work).For the engine I found a inner spring broken ( triple sprigs??) the roller is "Crane gold ".The manuals tels double spring....maybe I got an engine already " worked"??
duncan is offline
Old 03-29-2004, 12:27 AM
Received 1,815 Likes on 903 Posts
As far as the springs, you probably have a dual spring with damper in it.
Griff is offline
Old 03-29-2004, 07:50 AM
Yep,Dual spring with damper.Probably should change all the springs to be safe.BOB
Bob280Silencer is offline
Old 03-29-2004, 01:56 PM
thank you for your answers and please give me some references where I can get those springs and dampers,since I do not have the correct part #.
duncan is offline
TeamShogren.com
Outerlimits
0
02-03-2007 08:34 PM
thedonz
12
02-10-2006 11:12 PM
thedonz
General Racing Discussion
0
02-09-2006 02:59 PM
bshzba
12-19-2005 04:20 PM
ratman
4
06-23-2005 04:24 PM
Quick Reply: ssm-v & bulldog500
