Mechanical Fuel Pumps
Does anyone know who makes a hi-performance mechanical fuel pump I can run off my sea pump. I have a gen5 block and want to run a mechanical pump if possible, my sea pump has a spot to bolt a pump to it. Has anyone had experience with this type of set up?
Thanks J
Thanks J
Charter Member #737
Buy a HV Carter and use the top half from your old pump. The same thing CP Performance will sell you for half the money. You can pick it up at any performance auto parts dealer.
Charter Member #737
I went to a boat dealer and bought a used one. Paid 20 bucks and added the carter lower.
I have a fuel pump with a regulator and line kit that I ran with the Nickerson carb that you are interested in. We can discuss it more later after you find out if the carb is compatible with what you need. Are you going to need a flame arrestor for your new carb? I have 1 10" x 3" and 1 8" x 3. Both gaffrigs.
Charter Member #737
How much for the flame arrestors?
