3 qts. of drive oil. Where did it go?
Filled my drive today with Royal Purple. Pumped three quarts into the drain/fill hole while patiently eyeballing the vent hole, waiting for it to puke. Never happened. Drive was slightly raised (only a few degrees), so I lowered it, expecting the oil to come gushing out the vent hole. Nada. There are no leaks and no odor of Royal Purple (phew) anywhere.
According to the manual, my TRS (incl. reservoir) takes 81 oz. to fill.
3 qts. = 96 oz.
Should I just top-off the reservoir until full?
D. Ocean
Pompano Beach, FLA
3 qts. = 96 oz.
D. Ocean
Pompano Beach, FLA
Great news. That's the answer I was hoping for. What the hell good are manuals if they're inaccurate?
So, instead of gushing Royal Purple all over trying to re-install the pump, can I put the last quart in from the top or no?
D. Ocean
Pompano Beach, FLA
D. Ocean
Pompano Beach, FLA
I think you will have to put a clean pan under the drive, screw out the filler plug, put your finger over the hole, then remove it and install the fitting with the hose attached to the pump. Curse a lot, clean a little...but fill the drive from the bottom.
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
jeff32
06-28-2006 08:48 AM
Velocity Tom
07-16-2003 10:13 AM
