Lowered Dulley
#49
I knew you would chime in BYC. Here is a pic of the frame notch as we were widening the opening and rasing the notch section higher on the frame to accomidate the drop for the bag set up, didn't want the huge step notch in the bed so we did this, boxed the rear frame rails to the cab,and layed some square tubing on top of the frame rails with gussets comming down to make for the larger cut in the frame. Works great and no trouble out of it. with the standard notch no need to reinforce it the way we did. with the stck notch in, I went ahead and plated the back side as well.
