View Poll Results: What power would you take for same price?
Used 502 MPI with new bravo XR
9
45.00%
new 496HO with new bravo X
11
55.00%
Voters: 20. You may not vote on this poll
502 mpi/bravo xr OR 496ho with bravo x?
Here is a question or actually a poll for you folks. Say for example you were to purchase a new single engine V-boat i.e. Superboat 30y2k or Pantera 28 and planned to eventually supercharge whatever motor you were to get with it, and initially only had enough money for either the 496HO with standard bravo drive, or a slightly used (Less than 15 hours) 502mpi and a new bravo XR which would you take?
The stock 496 is not the best engine to try and supercharge. The stock compression is higher than the 502, which would mean less boost available to run, and the stock pistons are probably the weak link for this application. Now if you are willing to modify the 496 and change out the weak links, it may turn out to be the best choice. There are several aftermarket parts now or soon to be available that may make this engine the better of the two. Time will tell.
