?? Stereo speaker switch OFF/ON >
Old 04-22-2004, 09:54 PM
Charter Member #232
Audiofn's Avatar
There is a home audio company called Russ Sound. They make a on off toggle for speakers. This will last just fine in a boat as the unit is sealed to be in a wall. Hope that helps.
Jon
Put your best foot forward!
Audiofn is offline
Old 04-22-2004, 11:33 PM
Andy Buzz's Avatar
I have Russound switches in stock. Call 813-882-8477.
Andy Buzz
Andy Buzz is offline
Old 04-23-2004, 07:02 AM
Havasu Hangin's Avatar
Like steelware said, I would run a toggle switch in line with the amps remote turn-on wire.
Then, if you flip the switch off, the amps are off, but the head unit is still on.
No need to mess with speaker switches.
Havasu Hangin is offline
Old 04-23-2004, 07:05 AM
Charter Member #232
Audiofn's Avatar
The amps are for the outside speakers. As I read the post he wants to turn off the inside speakers that are mounted to his head unit power. No way to do that except a speaker switch. Some one mentioned a volume control. They are a big time no no if you ask me. I actually REFUSE to use them in houses. First off I do not make any money selling them but secondly I have seen them light on fire in walls, and as simple as they are customers NEVER seem to be able to use them properly.
Jon
Audiofn is offline
Old 04-23-2004, 07:14 AM
FIERCE ALLEGIANCE
Blue by You's Avatar
Jon
So Russound is the way to go?
Blue by You is offline
Old 04-23-2004, 07:16 AM
What the hell is a cabin?
How about running the amp RCA's off the rear low-level outputs, and running the cabin off the high-level front?
Won't they fade?
Old 04-23-2004, 07:28 AM
FIERCE ALLEGIANCE
Won't they fade?
I only have 2 speakers on the inside, run directly off the head unit. I have 3 amps powerwing 6 speakers and 2 subs in the cockpit. It's the 2 speakers inside that I just want to switch so I can quiet it down inside but keep the outside thumping. I figured switching the inside 2 speakers was the smartest move... but that's why I posted.
Attached Thumbnails ?? Stereo speaker switch OFF/ON-2826stereo_030-med.jpg
FIERCE ALLEGIANCE
subs
Attached Thumbnails ?? Stereo speaker switch OFF/ON-2826stereo_026-med.jpg
Old 04-23-2004, 08:07 AM
Charter Member #232
Audiofn's Avatar
This is a unit that will work. You just wire it backwards and when the switch is in one possition you get sound the other you get nothing.
http://www.russound.com/ab1.htm
Jon
Audiofn is offline
Old 04-23-2004, 08:10 AM
FIERCE ALLEGIANCE
Jon
Awesome...Thanks!
hp500efi
6
04-30-2007 10:47 PM
288sunny
2
03-13-2007 08:21 AM
IRONMAN
26
03-08-2007 08:41 AM
zimm17
6
07-13-2006 01:16 AM
Quick Reply: ?? Stereo speaker switch OFF/ON
