Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-12-2004, 02:19 PM   #11
Yes, I'm from KANSAS!!
FunHome's Avatar
28ft Saber, 22 Velocity
carb. 500 hp's are known for this after idleing for a long time!! And since it did this you'll need to replace the power valve's in the carb.'s
FunHome is offline   Reply With Quote
Old 05-12-2004, 05:49 PM   #12
cuda's Avatar
I don't know if this applies in your case, but in cars, the first thing I suspect with backfiring thru the carb is lean fuel mixture. Second thing is the timing off. The third is crossfiring.
cuda is offline   Reply With Quote
Sponsored Links
Old 05-12-2004, 07:33 PM   #13
Turbojack's Avatar
2003 Eliminator 30' Daytona
Quote:
This was my first though as I was reading all of the posts. If pop is when you press down on the throttle the engine is going lean & thus the backfire. I will say you have bad or sticking accelerator pump or something in that area.
Turbojack is offline   Reply With Quote
Old 05-12-2004, 09:35 PM   #14
10x
10x
10x's Avatar
1989 10 mtr Fountain
If it's backfiring under 2000 rpm, when trying to go on plane, it's possible you're puttin too much load on the engine.
When you lug a engine too much at a low rpm, it WILL cause a slow constintant backfire.
If it is a rapid backfire, start lookin toward the ignition for the problem.
These are some of the problems I have encountered in the past years. And I am assuming the problem goes away once you're on plane.
Try: trimming the drives a little more, when going on plane, so the props slip a little more, and see if that helps. If it does, you might have too much cup in your props.
Just speakin from experience, Frank.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
frank@chicagopowerboat.com
www.chicagopowerboat.com
10x is offline   Reply With Quote
Old 05-13-2004, 03:47 PM   #15
Krumbsnatcher's Avatar
Magic 1996, Wizzard 29.9
Quote:
I would agree with a lean fuel mixture if it had happened at a higer rpm, but the fact that it happened at 2,000 would lead me to cross firing.
I would check your plug wires and change the distributor cap. Was it a really loud backfire, or a small pop. If it was a small pop your power-valves are probably still ok.
When she does start is she running rich?
Krumbsnatcher is offline   Reply With Quote
Old 05-13-2004, 04:04 PM   #16
B-MAX REPAIR
WILDTHING TAZ's Avatar
OUTERLIMITS 97 STILETTO
IF YOU ARE RUNNING MSD DIST.& MSD BOX. MAKE SURE THE DIST. WIRER'S ARE NOT CROSSED!!! PURPLE GOES TO GREEN. I DID THIS AND SAME THING HAPPENED. RB
B-MAX "ONLY THE STRONG SURVIVE"
WILDTHING TAZ is offline   Reply With Quote
Old 05-17-2004, 06:31 PM   #17
Turbojack's Avatar
Re: Backfire Thru Carb
[QUOTE=Krumbsnatcher]I would agree with a lean fuel mixture if it had happened at a higer rpm, but the fact that it happened at 2,000 would lead me to cross firing.
QUOTE]
Nope, lean mixture will cause backfire from just off idle & up
Old 05-17-2004, 10:01 PM   #18
Crazyhorse's Avatar
38 Cigarette flat-deck
Mitch, give me a call. If you've got a Miller Lite or a Mick Ultra for Barb we can stop over and check a few things out. 738-0474 or 403-3962
Crazyhorse is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Backfire? madorno1 General Boating Discussion 1 09-23-2007 12:05 AM
engine backfire laszlo01 General Q & A 9 09-10-2007 07:05 AM
Engine Backfire speeddemon651 General Q & A 39 12-24-2006 03:01 PM
Carb backfire (lean condition) theory? jackhammer General Q & A 4 07-13-2004 09:01 PM
Backfire thru carb BAD-HABIT General Q & A 6 05-16-2003 09:35 AM
Search Engine Optimization by vBSEO 3.2.0
