Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-11-2004, 10:10 PM   #1
Removing Exhaust Tips
In trying to replace the stock exhaust tips on a Baja, I removed the screws but they won't budge. Are they glued or siliconed in? Any tricks to get them out? Thanks.
BajaBuddy is offline   Reply With Quote
Old 05-11-2004, 10:13 PM   #2
epeek's Avatar
35 Fountain Executioner
Probably siliconed in. I just pulled mine out. A real ball
buster!Pull real hard,the'll come.
epeek is offline   Reply With Quote
Sponsored Links
Old 05-11-2004, 10:21 PM   #3
Danny_Ocean
I whacked mine side-to-side with a rubber mallet. They eventually broke loose and I was able to wiggle 'em out.
D. Ocean
Pompano Beach, FLA
Old 05-12-2004, 07:58 AM   #4
97BossHammer's Avatar
yeah you have to break them loose a bit, BE CAREFUL not to knock them too hard. Just put a little force behind them and they'll eventually break free. I know what your going through, just did mine not too long ago and was wondering if I'd ever get them out.
97BossHammer is offline   Reply With Quote
Old 05-12-2004, 08:21 AM   #5
Cold as a Blue Dog
Airpacker's Avatar
little cat...BIG MOTOR
easy trick for removal. Use a small hydraulic bottle jack, some wood blocks and push them out from the inside. Works every time.
Happiness is a Boat and a nice bit of Tail
Airpacker is offline   Reply With Quote
Old 05-12-2004, 09:37 AM   #6
Danny_Ocean
If they are stuck to the gelcoat with 5200 or something similar, pushing them out from inside will most likely take the gelcoat along for the ride. I would break them loose first with the rubber mallet (and perhaps a razor around the flange) before pushing from inside.
D. Ocean
Pompano Beach, FLA
Old 05-12-2004, 12:19 PM   #7
Were doomed!
Wally's Avatar
Chris Craft Stinger 222
try some real thin piano wire and work it back and forth around the edge and behind.....that will cut the silicone away and help break them free...
-Wally
The dollar decides how far you can go....
AOL IM: bigblockwally
Wally is offline   Reply With Quote
Old 05-12-2004, 02:42 PM   #8
Krumbsnatcher's Avatar
Magic 1996, Wizzard 29.9
Use a small butane torch and heat them up, use a pair of pliars and they will come right out. I had the same problem when i replaced my tips.
Krumbsnatcher is offline   Reply With Quote
Old 05-12-2004, 04:15 PM   #9
Neno the mind boggler
glassdave's Avatar
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
i would try airpackers method but just pit enough pressure to get them moving than take a long razor knife to the 5200 to free it from the gel coat.
08 OPA High Points Champion
glassdave is offline   Reply With Quote
Old 05-12-2004, 08:36 PM   #10
1990 Fountain 29' twinBBC
Mine had o-rings behind a black plastic bezel on the transom. Once I got it out I couldn't get the o-ring back in.
cooltoys61 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
changing exhaust tips from muffler tips to straight tips bolgna General Q & A 4 01-23-2008 07:23 PM
Having trouble removing 1 inch tips from 98 312 fastech chattviper Formula 3 02-28-2006 11:13 AM
Removing Exhaust Tips Kokopelli General Q & A 11 12-30-2003 02:46 AM
Removing water from exhaust flow? Should I do this? Waterfoul General Q & A 18 03-15-2002 08:03 PM
Removing old exhaust tips pb General Boating Discussion 19 02-01-2002 07:45 PM
Search Engine Optimization by vBSEO 3.2.0
