something let go! >
something let go!
something let go!
Old 05-25-2004, 09:12 PM
micky dee
something let go!
twin 454's vee drive transmissins. boat is a wellcraft. so today while out something has happened? crunching noise in the transmission. engine seems to run fine but once in gear sounds like a bad bearing. any ideas?
Old 05-26-2004, 08:57 AM
Were doomed!
Wally's Avatar
Default Re: something let go!
did you try spinning the props while in gear? (engine off!) maybe the drive went!
-Wally
Wally is offline
Old 05-26-2004, 10:57 AM
Could be bearings, chain drive, or reduction gear (depending on tranny). Only way is to take it apart. Note that due to short prop shaft lengths on V drives, they more susceptible to engine alignment problems. Those are usually output shaft seals and bearings.
Gary
Gary Anderson is offline
Old 05-26-2004, 11:40 AM
marinetrans's Avatar
Center bearing in v-drive burned up or drive damper failed.
marinetrans is offline
Old 05-26-2004, 11:42 AM
Old 05-26-2004, 11:43 AM
Sorry hit the enter key to many times.
Old 05-26-2004, 01:54 PM
And here I just thought you were REALLY sure about it.
Old 05-26-2004, 08:55 PM
micky dee
o.k. , had the mechanic look at it today. so we started it up and in gear she went. no problems where noticed. thumping sound gone! hopefuly it was just a peice of debris that has freed it self from the shaft. i did notice a peice of blue camping matress foam floating beside the boat once we got it docked and things settled down.
cant wait to get her out again though, slowly ironing out the many problems we have had so far this year! thanks for the response!
