One drive trims faster than the other ???
Re: One drive trims faster than the other ???
I had the same problem last week,
see this thread: http://www.offshoreonly.com/forums/s...ad.php?t=81596
Thanks for the info.
It's just strange that this just started to happen after i pulled the drive and then re-installed the drive. How do i know if the Rams need to be rebuilt vs. the pump? will the Rams physically leak fluid past the seals ?
too tight?no...they are shouldered....
we shim everything VERY tight...a few extra #'s of force means nothing to something that can move thousands.
Originally Posted by audacity
inside on the end of the ram....ya put the trim limit spacer in the right way?
If so, when i pulled everything to replace the gimble bearing the spacers stayed on the insides of the ring. i didn't remove them. just put it all back the way it came out.
oh those celery sticks where the pin goes through. I actually didn't touch that either. i dont even remember seeing it. That side drive housing is original....did they have the oblonged rear pin holes in 1996 ? If so the celery stick was stuck in there and didn't fall out when i pulled the drive.
