oil cooler thermostate stuck open >
Old 06-30-2004, 03:21 PM
IndianaHeat's Avatar
Question oil cooler thermostate stuck open
a friend had a oil cooler thermostate stuck open. question would 2-3 hours running hard hurt the engine with hot oil. he currently has low oil pressure.
IndianaHeat is offline
Old 06-30-2004, 06:34 PM
Trippin's Avatar
Default Re: oil cooler thermostate stuck open
Oil Cooler thermostat?
A Lack of oil is causing a low pressure reading or a faulty circulating pump. Haven't seen an oil pressure thermostat yet. (Sending unit yes) An oil flow restriction is not a good idea.
Trippin is offline
Old 06-30-2004, 11:32 PM
Rob
Strip Poker 388's Avatar
I would think a stuck open oil thermostat would make the oil run cooler. The thermostat is to maintain the temp and warm up quicker..
Maybe you mean stuck shut?Cooking the oil reason the oil pres in low?
Strip Poker 388 is offline
Old 07-01-2004, 06:39 AM
yes ,stuck shut no water flowing thru exchanger .oil was hot enough it smoking out of the vents in the valve covers.
Old 07-01-2004, 06:46 AM
dont know if he has 2 problems or if the the oil getting over heated compounded the low oil pressure problem . told him to change the oil and filter.
Old 07-01-2004, 07:18 AM
Rob
If it was stuck shut the oil broke down. I bet it turned to sludge .i would pull the valve cover and ck how bad it is. We had a company truck do this and the oil pres went to zero and started clattering . towed it back pulled the oil pan changed the oil pump and the bearings looked OK .Lucky .we shut it down in time .
t500hps
07-17-2012 09:23 AM
J. Hordubay
13
10-02-2008 01:55 PM
31scarab31
2
02-29-2008 04:14 PM
slik22
Wanted
6
01-08-2008 04:13 PM
patrick22309
5
06-20-2003 05:53 PM
Quick Reply: oil cooler thermostate stuck open
