How do I get ~450hp out of Merc 454 -95? >
Old 08-26-2004, 03:57 PM
  #31
tomas_wallin's Avatar
Default Re: How do I get ~450hp out of Merc 454 -95?
I didn't really count on this kind of interest in this tread...
I thank you all for the all the valuable answers. All I have to do now is to persuade my two "partners" in the boat... But since we have a 350 that we are gonna fix and sell during the winter, that shouldn't be a problem!
It's pretty sad that here in Sweden the 174 costs about $4000 and a new carb is about $650. So Im gonna look around in the states for a good price since the customs and taxes ads about 30% if I import the parts...
The boat makes almost 60 with the 454 and a Mirage 27P, I have to get a 25P to get it up to ~4500rpm. So about 10-15 more I hope... But you never get satisfied!
Thank you all,
Tomas
tomas_wallin is offline
Old 08-26-2004, 06:03 PM
  #32
Originally Posted by Budman
Can anyone answer my original question? My engine already has about 9.2:1 CR. Is this too high to run a supercharger, even with 93 octane? Would 4 psi of boost be too much for this setup? Is so, do they make pulleys that will reduce boost below 4 psi?
Alternative would be to build a 502 and stay normally aspirated. My current 454 only has about 200 hours on it. It is based on a 2-bolt cast crank motor, but has forged pistons, polished & shot-peened rods with the ARP bolts, ported oval heads (upgraded to 2.19 valves), etc...
Thanks, Tom
Budman! I Agree with Gary 9.2:1 is asking too much for 92 octane pump fuel! At 9.2:1 and 4 psi of boost it puts you above the effective comp. ratio of 10.75:1 to run pump fuel! That added with the air-fuel temp rise and no inter-cooler, just not a good candidate for a blower on pump gas!
And Gary you are absolutely correct, that on the 330 upgrade no ignition change is required, but I just love those DUI so much, they are so clean and run so crisp, if my Hummer wasn’t a Diesel I would have one in that as well! Cheers!
bpine is offline
jdub
4
10-08-2006 11:08 PM
morris440
04-24-2006 06:29 PM
jhoward
11-27-2005 08:29 PM
Dirthead
33
01-14-2005 08:00 PM
chuckbeecher
06-04-2004 07:51 PM
Quick Reply: How do I get ~450hp out of Merc 454 -95?
