Go Back   Offshoreonly.com > Technical > General Q & A
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 09-03-2004, 09:47 AM   #21
2002 Sonic 386
Re: Oil Filter Study
Where's the best place to get mobil 1 filters? My parts dept couldn't locate them locally.
King Julian for President 2012
GO4BROKE is offline   Reply With Quote
Old 09-03-2004, 11:56 AM   #22
SORE MEMBER
GMC Duramax/Allison 4x4 STRYKER EQUALIZER 29
Quote:
O'reilly, pep boys, autozone all carry line but do not always have stock
Wobble is offline   Reply With Quote
Sponsored Links
Old 09-03-2004, 12:05 PM   #23
SORE MEMBER
Also this may help
http://www.mobil1.com/index.jsp
Old 10-18-2004, 12:23 AM   #24
Grease
Quote:
Originally Posted by Hydrocruiser
This study was reviewed on Bob's oil website. A few conclusions were drawn:
- The study used oil at a viscosity of 30W-70 mixed with glycerin at 70*F
-It was a "hobiest" that did the study with a budget of $ 150.00 total.
-The oil used was non-synthetic
-Flow-rates were measured at 10 psi.
So what are the concerns?
-Nobody uses conventional oil mixed with glycerin in an engine as the test did.
-30W-70 viscosity was used and is unheard of and not sold commercially.
-Oil flow would need to be measured at various temperatures from 50*F to 200*F for this to be realistic.
-They did not compare flow rates for synthetics vs. conventionals as synthetics flow better.
-They did this test at 10 psi which is not enough pressure to adequately demonstrate the flow-rate of the filters realistically.
So whereas their findings may be accurate there are other oil filter studies that are much more scientific.
I hope to clarify a few things from these comments. There a lot of misunderstandings.
"A 30-70 weight oil was used." I couldn't figure out where this came from, then I realized what the confusion was -- No, a non-detergent 30 grade oil was used at 70 degrees F. A non-detergent oil was used because additives in detergent 30W oil were giving inconsistent readings with the test equipment. A 30W oil was used, again, for consistency in test results.
"Oil was mixed with glycerin." No, oil was tested thru the filter media, then glycerin was tested in a separate test to insure accuracy. Glycerin is used commonly with bubble testers as a neutral benchmark fluid.
"It was a "hobiest" that did the study with a budget of $ 150.00 total." While, yes, I am a hobbyist, the media was tested by a professional in the filter industry. The $150 was for filters paid for out of my own pocket. The testing would have been prohibitively expensive had I paid for it and I think added considerably to the study. Without it, the study would been just another can opener test.
"The oil used was non-synthetic." Yes, but the oil used was the same for comparison purposes. The numbers mean nothing by themselves. Comparing the numbers gives us relative standings amongst the filters. If a filter flows twice as good as another with dino oil, it will probably do the same with synthetic. The same for 70F vs. 200F.
"Flow-rates were measured at 10 psi." Yes, but it was also tested at 20psi. Tests were done at both psi settings to make sure that "relative" trends between the filters registered consistently. 10psi was used for the final flow numbers because that test was run for twice as long as the 20psi tests. No, your boat doesn't run at 10 or 20psi, but these were the settings of the test equpment to give relative results.
I hope that clears up the confusion on some of the misconceptions about the study.
Personally, from the test I will run Hastings LF279, Purolator Premium Plus L34631, or K&N 3002. I have a Hastings LF279 lined up for my next filter change. These three filters mentioned flow as good or better than the Merc and filter better. I'm surprised to read on this site that many of you are running M1 302's as I witnessed them to flow half what the Merc filter does. I could see an argument for an Amsoil SDF24 in a boat as the flow is just about up with the Merc.
In a car, all bets are off an you can choose your favorite, but in a boat, if I am going to run anything other than OEM, I'm choosing one of the above four.
The key columns to look at in comparison are "I" and "L" that are bolded in the spreadsheet for filtration and flow. http://www.oilfilterstudy.com/Grease...er%20Study.xls
I will use the misunderstandings listed to make better explanations in the text of the study.
If you have any other questions, please let me know.
I'm reading more on your forum to learn more about boat oils as I am still undecided on what I want to run.
My last UOA showed a 6% fuel dilution after 53 hours, so I am going to run shorter OCI's. With OCI's at ~25 hours, I am reluctant to go with high end oils because of the price.
Cheers,
Grease
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
496 oil temp senders remote oil filter Velocity Vector General Q & A 0 04-03-2008 02:45 PM
Merc Oil Filter Study Grease General Q & A 29 06-04-2004 07:45 PM
New oil filter study released Grease General Q & A 19 05-29-2004 01:32 PM
Just changed the oil/filter and the oil pressure is higher than normal JGB General Q & A 18 06-06-2002 10:13 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
