More HP for HP 500 >
More HP for HP 500
More HP for HP 500
Old 09-03-2004, 03:30 PM
  #31
cstraub69@comcast
Default Re: More HP for HP 500
Yes, the exhaust is raised .600" like most others.
Chris
Old 09-03-2004, 03:39 PM
  #32
Rob
Strip Poker 388's Avatar
The only aluminum heads I have heard that are not is the Eldebrock.I don't think they have very good port velocity.
What about the pro 1"s??
Strip Poker 388 is offline
Old 09-03-2004, 11:00 PM
  #33
WAGS382's Avatar
Strip Poker 388
AFR told me the exhaust is raised .375".
WAGS382 is offline
Old 09-07-2004, 06:01 PM
  #34
WAGS382's Avatar
Does the 741 cam help the performance of a stock HP 500 (carb) ?
WAGS382 is offline
Old 09-07-2004, 07:33 PM
  #35
no disrespect to anyone but no way now how is a 500hp carb motor with a cam and 315cc cnc ported heads going to make 600hp at 5400-5500rpms. sorry it is just not going to happen on pump gas. save your cash cmi's are not going to do anything beter than your gill's. in a perfect world with afr heads, bumped up timing a little, bumped up comp. a little and good cam you might gain 100hp. a stock 500hp is like 465hp.
502procharger is offline
Old 09-07-2004, 08:26 PM
  #36
While we are on the subject, on a carb HP 500 what rpm's do you prop for to obtain max top end speed?
RickR is offline
Old 09-14-2004, 02:17 PM
  #37
4800-5200 - labbed 26 4 blade on a 288 sunsation ,
firstborn is offline
Old 09-15-2004, 12:46 AM
  #38
Rob
Originally Posted by WAGS382
Strip Poker 388
So on a side by side installation the stock cmi headers should not touch.
I wonder if there is enough slack in the hose to accept the .375 higher exhaust port to line up with the tail pipes???
What do yall think??????
Rob
Old 09-17-2004, 01:11 PM
  #39
I am considering changing the heads and cam on my HP 500's. I am very interested in the AFR 315 cnc heads with a Crane 741 cam. I would like some advice from the engine experts out there. Do you think the 315 cnc is the right head or the 305 with cnc'd chambers. I spend most of the time running 3500-4000 rpm. I am looking for alot of mid range torque and a solid 600 HP. Thanks in advance for the advice. Jeff
Hey Jeff , Drew here, You can always do what I did Blow A Motor and step upi to 540,s... Runnong a strong 80 plus right now !!!
boatman747 is offline
Old 09-17-2004, 01:21 PM
  #40
Charter Member #139 /Moderator/Platinum Member
klaw's Avatar
Rob
if you use the CMI with the flex flairs the tail pipe has some adjustability. If you buy a used set even if they are the cool collar design make sure the tail pipe connection is the flex flair design the one they make for Mercury are not.
klaw is offline
Quick Reply: More HP for HP 500
