why do blower engines surge at idle?
Re: why do blower engines surge at idle?
When an EFI does this it is caused by poor ECM control over higher flow rate of the injectors commonly used in racing applications. When this happens the IAC attempts to do it's job causing the engine surge like the one Cord describes in the Sorcerer. (turn your speakers up) A proper running EFI engine may do this only after a reprogram or reset.
A carb engine's cause for doing this could be anything. But who cares because carburetors suck
Roby
Roby
Originally Posted by Quiet Storm
My 99 Suburban acts like it has blower surge. Drives me crazy.
Roby
As stated above normally the "Surge" "Lope" "Roll" or what ever you want to call it is from the carburetor, or ECM being out of adjustment. The Solenoid that Sterling, and some others use is designed to Raise the Idle RPM to a higher level when putting the boat in gear. This may be needed if you're running a very low gear ratio in your drive, with a huge prop.
We actually had a guy try and return a set of carburetors we built because the idle was smooth, and not surging.
Charter Member #655
I love to hear it !!!!!Makes the hair stand up on the back of my neck!!!
If your boat has a sail do you ride a horse to the ramp?
Originally Posted by robyw1
might want to have it checked out. The ECM may be losing power when ever you turn the key off. If this is the case it will surge on start up to warm up. If it is surging while at operating temperature then you likely have an IAC malfunction but this should turn on the check engine light.
Roby
Roby
OK, back to boats.
Roger
Originally Posted by Cord
The Sorcerer is injected and has a slight blower surge...
And it probably has about 12 lbs of boost at idle
when we dynoed mine it ran smooth on the dyno. I put it in the boat it went to surging ,probably because of water temp.
I liked the surge. Always ran it alittle fat to be on the safe side but it did not burn your eyes at idle.just one # up on the rears.
The main reason, I needed it to surge so I could shift the bravo drive on the down cycle so it would not bang going in gear
[img][/img]
[img][/img]
