Merc 600sc?Any Good?
Re: Merc 600sc?Any Good?
Originally Posted by RHC
Mine just went over 400Hrs this past week,,, 1997Apache ,, with bravo XR's ,,, do not use Oil,, and have never been opened up(apart) I run 32-3500 most of the time ,,, wil run a poker run leg,, about 30miles ,,,, wide open and dont have to worry about these engines,,, they are thirsty ,,, I can get a mile and a quarter if I stay at 3200 over that ,,,, forgettaboughtit... 5 Lbs of boost and 92Octane... Great engines ,,, Check the compression,,, should be 135lbs with 7 1/2 to one ratio ,,, thats factory spec.
RHC
RHC
Just curious as to the oil temps you're running when she's flat out for extended periods, because my starboard motor runs oil temps of 260 when I push her hard.
RHC
Josh,, I just reread your first post,,, The good thing about the package your looking at is the #5s ,,, the 600sc engine has a lot of untapped Hp left in it ,,, the cams are very small,, the timming is conservitive from Merc and the compression is only 7.5 to 1,,,, of course when you start changing things you lose relabilty!!!! however 650 to 700hp is well within reach and of course intercoolers are always an option,,, the down side ,,, I have yet to find pulleys for the 420B&M blowers ????? anybody??
RHC
RHC
Originally Posted by CNC
Perfectmix,
Are you lookin at that Velocity? I'm going tomorrow to inspect it.
Josh
