Electric Trailer Jack
Anybody using and electric tongue jack? What brand are you using? I was looking at the Atwood Marine unit but it only has a 1000# capacity. The marine unit just means that it is a side mount with caster. They have higher rated ones but they are for the A-Frame coupler. Any thoughts?
Thanks, Todd
Thanks, Todd
Toxic FORMULA
Re: Electric Trailer Jack
I have an Atwood unit for an A frame front on the trailer. That thing can darn near lift the back of my F350 off the ground Also has a built in light which is nice for night use(you can see what you're doing)
Charter Member#157
Thanks, Todd
Thanks, Todd
and how much$$
I have thought about too.
However my tongue weight is about 800lbs
This Cat is trying to keep up with the Big Dogs
Toxic FORMULA
Check this Particularly Troutlys info.
http://www.offshoreonly.com/forums/s...ad.php?t=86468
Thanks, guys. I have been thinking about the Atwood because it seems to be the most reasonably priced and the manual override can be activated without disassembly. I looks like I will have to go with the A-frame model and do a little fabricating to make it work with my Al I-beam trailer.
Toxic FORMULA
Mine bolts between my I beams. I'm in work right now but can take a picture tomorrow if you like.
dukenrock
6
05-04-2007 05:46 AM
dukenrock
13
02-16-2007 05:20 AM
