Fuel sender/fuel tank ground?
SORE MEMBER
1 Post
Re: Fuel sender/fuel tank ground?
Originally Posted by mhawkins48
Battery is fine as is engine block, whatever works out neatest.
Mark
Mark
Mark
Very good! Thanks for your help mark. The battery is closer, it's actually under a molded in back bench seat and not in the engine compartment. thanks again!
Jim
Jim
ok, That's what I was getting at. why do you do that? I assume just out of convenience but is it more unsafe to ground directly to the battery if you wire it to the correct(negative-black) terminal?
JIm
JIm
Originally Posted by JGB
I can just as easily run the wire back to the dash. Could I ground it directly to the fuel gauge ground?
Yes, but what you don't want is any chance of having somebody connect 12v+ someday instead of 12v-, especially if it has another ground as well.
BOOM.
That's what Mark was getting at.
SORE MEMBER
1 Post
Mark
