Stock 502MagMPI Rebuild >
Old 01-27-2005, 12:37 PM
Pat McPherson's Avatar
Default Stock 502MagMPI Rebuild
I have a 1997 502MagMpi with 480hours.
My plan is a stock rebuild: Rings, Bearings, Valve-Job...
I started stripping it down a few days ago and I'm putting together a shopping list.
So far I have new lifters, rockers, timing chain set for the Valve train.
Do I need new valve springs when the valve job is done?
Any other parts I should consider?
For the Short-block: rings, bearings, oil pump
How about the rod bolts? should they be replaces?
Anything else a weak point?
Thanks for the help,
Patrick
Pat McPherson is offline
Old 01-27-2005, 01:38 PM
Dave1972's Avatar
Default Re: Stock 502MagMPI Rebuild
Pat,
Go with roller valvetrain and you will love the difference. If you upgrade your cam slightly and get your ECM reprogrammed by someone reputable, you will be very surprised at the end results. I believe if you do a search on 502MPI or 502EFI upgrade you will find lots of good information.
Dave1972 is offline
Old 01-27-2005, 02:04 PM
Dave1972,
It's a Gen VI roller motor. No plans to change the cam, but If I have the heads ported, Mark at Precision will do the ECU.
dahkem1,
OK, new valve springs, retainers, locks, and APR rod and head bolts. I think I can spend the few extra $$.
Patrick
Pat McPherson
45
10-20-2008 08:39 AM
Pat McPherson
15
09-15-2007 07:07 PM
schdp
Baja
2
08-19-2007 09:33 AM
Canada Jeff
10
09-03-2006 02:02 AM
Pat McPherson
14
12-27-2005 11:33 AM
Quick Reply: Stock 502MagMPI Rebuild
