TCI, ATI, Fluidampr...........
Re: TCI, ATI, Fluidampr...........
The coating on the ATIs is zinc chromate not anodizing. I believe that is pretty corrosion resistant.
Originally Posted by MYPANTERA28
Stay away from fluid dampners, go wit a Romac or ATI, balance is the key in any engine.......
Who is Romac???
2112 they will get a chalky .The allen head counter sunk bolts will rust also It kinda looks like gun blueing?
Just get them allready chrome.
cstraub [Chris] you know I know what you sell. I have a account with you
Rob
So,,, where does the stock dampener play into this mystery. Ive use nothing else for years and never had a problem that could be linked to the balancer.
The reason NASCAR cars use ATI dampers is because Fluidampr’s are against the rules. The silicone fluid in a fluid will never go bad if the damper is replaced at major overhauls. If you overhaul the engine several times over many years and just keep using the original Fluidampr then is possible that it might fail.
You do not balance the crank with the Fluidampr installed. Each component of the Fluidampr is precision computer balanced prior to assemble at the factory in Springville NY. During final assemble the viscous fluid is added, you cannot balance a fluid. So the proper procedure is to install the Fluidampr after the crank is balanced.
Here is a good explanation for how they work http://en.wikipedia.org/wiki/Harmonic_balancer
Or check out www.fluidampr.com
But how do you tell when one goes bad?
If you replace the Fluidampr with the other parts that need replacement at your major overhauls the fluidampr will never go bad.
Also how many miles,hours,time ya recomend [think] we should do this.
I have a Chrome Fluid D on my street/race car with about 40k on it.
Rob
