Re: Outdrive loose
I've had this same problem.
On the top center of the outside gimbal assembly, there is a single pin for left/right stearing of the outdrive , I believe it is triangular in shape, hard to see, but can be seen. Again, from the outside of the boat, there are two bolts that can be tightened to secure the seating of the triagular pin. I don't have the torque specs for a 2001, maybe someone else can help out here. I'd make sure these bolts are checked first to assure proper assembly and torque. Once this area becomes loose, it wears pretty quickly and requires replacement. I was able to tighten them a little more than the spec torque rating and it took the slop right out. If you find the triangular pin and move the drive left/right, you'll see the slop area.
If you determine you have to replace the parts, please post your experience in perfoming the task. Good Luck!
