Where can I research oxygen systems?
any of these boats have a bilge pump on the ceiling for when
they turn over, sounds like a good idea to me.
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
Mario Andretti
A to Z
I'm sure there are a couple systems out there, but all function about the same way. being ex-fire, our scba systems gave us 20-30 minutes air time. They functioned with a 'demand valve' where high pressure air is fed into the regulator, then only into the mask as it sensed you breathing in. it also had a purge feature that allowed you to manually open a valve on the regulator allowing additional air in. The system had positive pressure in the mask preventing anything from seeping in past the face seal. the system also had an extra hose so that you could use a buddies air or they could use yours in the event of depletion or malfunction as well as an air powered low pressure alarm. The bottles were fairly small and the alum/kevlar bottles were light. I would think you could easily get 1/2 hour out of a standard bottle racing, as I was able to get close to that wearing full turnout gear (which isn't light) and working pretty hard.
as far as researching systems, basic google of scott and msa scba systems as well as scuba systems should give you a lot of info.
Racer
Racer
Most Canopy race boats are still using a standard scuba system hard installed in the boat with 20' of hose. The boat you are looking at would almost certainly have this type of system. One large scuba tank with a pressure gage and 2 lines running to the seats with standard mouth regulators. It is by far the least expensive system and many prefer not to wear the "Fighter" mask for comfort.
You should understand that that boat was built with only one goal in mind, to race. They do not make great pleasure boats. No room for 5 babes or coolers.
Racer
Racer
You should rent a BAT BOAT at worlds...get your feet wet. No better opportunity to do so at a fraction of the cost or investment! You can even get a few sponsors to help offset the cost. The boat looks cool as hell and is a riot in the KW waters!!!! I had my current wife race a bat boat so she would understand more about what we do.
uhmmmm Rick, not to sound like a diss or anything, but after seeing so many different types of vehicles involved in violent crashes, you might mount that a little more securely than 2 hose clamps. the clamping strength is good, but the attachment point has little mass and a lot of shearing potential...
i would never want the bottles where we are at...they break off in a crah(they will) and they will kill you like right now if they hit you! the damage bottles do to boats is nuts.
even these were scrapped and new ones designed and fabricated by turbine marine for our boat.
Rage
11
08-06-2007 01:44 PM
