Spare Air???
Fast Singles Club
Funny i should find you in this thread . Apparently the title of this thread drew us like moths to a flame . Remember guys if you have to go on compressed air to Never hold your breath upon risk of ruptured lungs . If you and your air supply become separated while underwater , exhale on the way up !! This way the expanding gas can escape without causing an embolism . I hope someone finds this information useful . deep
Fast Singles Club
Lay your bottle next to you in the bathtub , fill the tub as full as you can with water , lay down next to your bottle and take as big a breath as you can , hold your breath and set up . The air sacs (avioli) in your lungs will start to rupture . It is that critical !
There are many configuation options available,,,
As a SCUBA Instructor, I think the most valuable tools are:
#1 SCUBA certification, experience and confort under water
#2 Then of of course air,,,
Cheers
Cheers
Thanks for the information, but to expand on it, and correct some of your suggestions,,,,,,,,,,:
The inherent issues to a typical diver; (Nitrogen Narcosis, AEmbolism, Over-Expansion Injury, Bends) are not so inherent to a trapped racer. Most of these are due to depth, time, and accent rate, and in a boat racers the most critical issues are access to the air supply, amount of air supply, comfort with the system, and being able to mobilize out of the vessel with the co-pilot. Risks associated with depth and time are less of concern.
Air is 21%O2, and enriched air can be blend above 21% ( NITROX). Indeed that air embolism is a risk inherent in scuba diving, it would not apply to boat races in an overturned vessel. And like most physiological problems in scuba diving, the risk is due to the diver breathing air at high pressure .Holding the breath on ascent one of the causes of an air embolism. As the diver moves from high pressure at depth to a lower pressure at a shallower depth, but this is not really the issue for Boat races that roll-over. The pressure change in 3-5 feel is rarely going to result in a Air Embolism(AE) or Over-expansion Injury( OEI).
Most teams have enough scuba hose to leave the cockpit, swim out to the other side of the boat( 20'), so the effective depth is max 3-5'. At the end of the day, practice and familiarity is critical.
Cheers
Fast Singles Club
Thanks for the information, but to expand . The pressure change in 3-5 feel is (rarely) going to result in a Air Embolism(AE) or Over-expansion Injury( OEI).
(Most teams) have enough scuba hose to leave the cockpit, swim out to the other side of the boat( 20'), so the effective depth is max 3-5'. At the end of the day, practice and familiarity is critical.
Cheers
Cheers
We will have Spare Air in the new boat. I will need help holding Lee down to strap his on.
Driver Team DVC S12 Super Stock
Offically certified fastest Super Stock raceboat. SBIP rules APBA U.I.M. attended/certified Kilo's 8/04 and again 8/05
8/07 119.14 MPH Worlds Fastest Super Stock
Orders for 08' DVC hulls now being taken.
