Go Back   Offshoreonly.com > Race Talk > General Racing Discussion
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 04-26-2004, 09:32 AM   #1
Wild's Avatar
500efis`
Just went from HPs to EFIs,
What are the rpm limits on this, I think i am reving to high and need to get some bigger props.
Randy
Wild is offline   Reply With Quote
Old 04-26-2004, 10:21 AM   #2
29/35 Fountains F1/P4
The rev. limiter is set at 5250 on the 500 EFI
F1-00 Racing is offline   Reply With Quote
Sponsored Links
Old 04-26-2004, 10:35 AM   #3
Wild's Avatar
So if my gauges are reading 5400 they are wrong, the engines will stop themselves at 5250?
Old 04-26-2004, 11:03 AM   #4
Charter Member #94
Gordo's Avatar
1999 Active Thunder 25' Factory 1 Race Edition
Randy,
I believe the rev limit on the HP500efi's are set at 5400RPM's. The 502 Mag efi's are 5250.
What props are you running now?
Abby-someone
Gordo is offline   Reply With Quote
Old 04-26-2004, 12:54 PM   #5
Wild's Avatar
Bravo, 28s
Old 04-26-2004, 06:53 PM   #6
They are set at 5250,but the tach will run up higher. When u get up to 5400 ,5500 the rev limiter will kick in. You can still turn higher R's you will just loose HP. When your on the limiter,the engine will start to cut out cylinders automatically. Its not like the old day when u hit the limiter that the engine would shut down. Now you only loose one cylinder at a time in the firing order.
Frank
"Koolhand"
Old 04-26-2004, 09:18 PM   #7
Administrators
Don't ruin those motors, I took good care fo them. 5250 hotrod
OffshoreOnly is offline   Reply With Quote
Old 04-28-2004, 09:35 PM   #8
John B's Avatar
36 skater
I was told by Mercury High Performance that the 500 EFI rev limiter is set to drop 1/2 of the fuel injectors at 5450 and will not turn them back on until the RPM's drop under 5250+-. This makes it seem like the limit is 5250, but if you sneak up on 5400, no problem. In racing your screwed since its almost impossible to stay in the water all the time without overreving.
John B is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Powerquest=500efis how fast? Velocity Tom General Boating Discussion 4 06-15-2007 12:51 PM
'01 38 Scarab with 500efis ? 5PMSMWHR Scarab 3 01-01-2007 08:37 AM
500efis tear down Wild General Q & A 2 03-15-2005 09:59 AM
500efis with XR Wild General Q & A 21 01-09-2005 04:12 PM
what to do w/ my 500efis? dreamer General Q & A 4 12-16-2003 09:06 AM
Search Engine Optimization by vBSEO 3.2.0
