One heck of a mechanic.
Heard about a Mercruiser mechanic in the Toronto area. Think his name may be Frank. Apparently he's the go to guy for Merc power. Heard alot of talk about him but no one seems to know where he is. Even my dealer is aware of him, again no contact info. If anyone knows of this ghost mechanic could you help me out with some way of contacting him. Thanks Peter.
Next question, just got off the phone with Procharger and they tell me they quit making blowers for marine use back in 04. I have a 01 Baja 272 , but the motor was re and re'd in 2011. It has a 502 HO new out of the box. Not looking for Roots style. Any ideas? Really like the idea of a belt driven turbo.
Don't know anyone by the name of Frank off the top but have you tried Entec in Scarborough?
http://www.entecracing.com/index.htm
Could be...I know they took care of a lot of the big boys on Simcoe - Libel's ect.
I would never use Entec again! I had 2 engines done by them -- ruined 2 pair of AFR heads that were brand new. I also have seen 4 other engines pulled apart after they had 'rebuilt' them that were a total mess.
It looked as if they had the high school auto class come in and do there work for them, and they charge as if they know what they are doing...
Big NO on ENTEC
dave
Big NO on ENTEC
dave
Big NO on ENTEC
dave
Big NO on ENTEC
dave
Peter -- the small procharger on a 502 will be fine on your boat and i would think would really wake it up. The weak link will be the bravo, the procharger is the best possible solution as it does not give the bottom end torque that a roots or whipple will. If you are easy getting up on plane and not airing the boat out all the time the bravo will live for a while. Some guys say no problem -- others will tell you it won't last long. Make sure on your throttling arm, and change your drive oil every 10- 15 hrs. If it were me i would hook up a cooler/filter to the drive -- they help alot and for the money are cheap.
There are some good engine guys around Detroit that could do whatever you need, where are you boating?
