Go Back   Offshoreonly.com > Owner's Forum > Hustler
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-30-2009, 10:06 PM   #1
Donzi 38zr - Ilmors
Prop Suggestions For 388
I just had the 500 efi's in my '02 Slingshot rebuilt and stepped up to 600's with the Tyler Crockett package. For anyone running approx 600hp - what props are you running ... assuming no changes to the rev limiters? Any input is appreciated.
myvalium is offline   Reply With Quote
Old 07-31-2009, 02:21 PM   #2
Rob
Strip Poker 388's Avatar
Hustler 388
I would of raised the rev limiters!! I was turning my 500efi 5400 stock,I think I saw Dustin Whipple post that they make power to 5600 stock around 540hp.Did Tyler dyno it and what rpm is peek hp?
The 388 comes stock with1.50 30's,ya might step up to 32's or labed 32's.or buz it
I went up in power around 80-100hp each went from 28-to 30's it would still pull the 30's to 6k then I tried some 32's it felt lazy,loading the drives harder,still ran the same speed at the 30's but at 55-5600rpm,hope this helps,Rob
Strip Poker 388 is offline   Reply With Quote
Sponsored Links
Old 08-05-2009, 10:44 AM   #3
Donzi 38zr - Ilmors
Thanks for the input Rob. Tyler put together the upgrade kit, but my builder in NJ bolted it on with the rebuild. No dyno but Tyler insists, even with stock heads, motors will be at approx 600hp. Rev limiter remaining the same was Tyler's call. Haven't pushed past 5000 rpm yet ... trying to behave on the break in. I have labbed bravo one 30's that I sent to bblades to tweak for the added hp. Seems like they won't be enough blade for the increase hp. @ 5k I'm only seeing 80mph - I would have expected 84-85. I thought 32's would be the way to go, but your experience with them @ similar power wasn't great.
Old 08-05-2009, 08:46 PM   #4
2000, HUSTLER 388 SLINGSHOT
myvalium
Can you give a little more detail on the engine upgrades. I would like to upgrade after 1 more season. Keep us updated on the prop testing.
Rob
Have you done any testing with any 5 or 6 blade props? I know our boats become more of a handful past mid-90's will 600 hp put me in that range, more concerned with cruise speed.
Thanks Steve (didn't mean to hijack)
NEVERSATISFIED is offline   Reply With Quote
Old 08-12-2009, 12:33 AM   #5
Rob
Hustler 388
Quote:
Originally Posted by NEVERSATISFIED View Post
myvalium
Rob
I have not,If I proped were it would pull the 6000 I think it would pick up some speed,but nore sure it can be conrolable,Alot of the outboard guy and the pad bottoms say drive ,learn,ballance it and the B BI gotten alot better sterring it,but it can still catch ya,a few times iv been to the rubrail,it will get ya thinking if its throws ya out you g=hiy the water,ya knocked out,if ya wake you here got the big gulp of water
use your old ones to get a line.
i would like to try the 28
hollaaar,6012597332
Old 08-18-2009, 03:29 AM   #6
Running 630 hp with 4 blade bravos 32p 1.5 ratio
64mph@4000
75@4500
85@5000
90@ 5400
Trying labbed 34s at the moment but no luck as sea not right yet and could not get over 85,
and difficult to get on plane
will post when properly tested
And yes its get very lively at high speed!!!
Fred
mossfred is offline   Reply With Quote
Old 08-18-2009, 12:04 PM   #7
SLOWRIDE-388's Avatar
We had stretched bravo 30s on ours, 1.5 gears, imcos on stelling boxes. These were the best running props for the boat, do not know who did them and what they did, they came with it. The only neg thing was they ran more rpm cruising than what we liked. Motors were dynoed at 640.
Boat ran 92 on gps, light load, and still had some more left.
Good luck with the boat, just takes time and patience.
Ben
SLOWRIDE-388 is offline   Reply With Quote
Old 08-18-2009, 05:21 PM   #8
Ben
Hi Ben,
Do you recall the rpm at 92?
Fred
Old 08-18-2009, 09:32 PM   #9
I currently have labbed 30" bravo's and can spin they 5200-5300. Does everyone think the bravo's are the best props to use on the slingshot's
Thanks Steve
Old 08-18-2009, 10:29 PM   #10
I believe it was some where around 5200 rpm Fred. Was not in the boat at the time.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
