39 Rockit Stereo questions
I'm about to do some stereo work on the 39' Rockit on KY Lake. The stereo that Hustler installed is nice, but the owner wants a little bit more. I stopped by his shop the other day to look it over for a few minutes. I didn't take anything apart just yet, but I need to know what amps Hustler installs in these boats at the factory when they're being built. The only speakers in the boat are the JL components and 10" woofer under the rear bench. The components will stay, but we may be installing 3 Wet Sounds 10FA's under the bench, replacing the 1 10" that's down there. I'll probably be changing out the amps as well, depending on what's in there. I'm almost positive that the amps are behind the electrical control panel that houses the radio, but without taking anything apart just yet, I don't know for sure. I'm hoping someone here can shed some light on that for me, so my questions are:
1. If the amps aren't located behind the head unit, where are they?
2. What amps are installed in the boat from Hustler?
Thanks in advance!
Thanks in advance!
How do the FA's work under the bench seat? Does the rear bench seat not seal well enough when closed to form an enclosure?
I have wandered with some of the marine subs being optimized for FA applications how that works. I am assuming the 3 subs will be mounted to the front (baffle ?) of the rear bench and if so, that seems like more of a sealed application.
Do you mind giving some more details?
This is the FA woofer that I use: http://www.wetsounds.com/pages/products/XS-10FA.html
Stereo is almost finished. The amp turned out to be a Kicker ZX700.5, and it's under the actuator in the gunwhale that moves the cabin door open/closed. The door has been disassembled and I've had to crawl in and out of it several times. New amps are installed: Wet Sounds Syn1 1000W mono amp, and Wet Sounds Syn4 800W 4-channel amp, are being installed in the same location on the gunwhale where the Kicker amp was. A Stinger SPP2150 battery is being installed in a battery tray next to the stringer that will be under the sliding door when it's complete. A Stinger SBC6A on-board charger/maintainer is being installed next to the battery and will charge the battery after each use. I'm also cutting in another set of JL M770 components behind the bolsters, and 3 Wet Sounds XS-10FA's under the rear bench. Battery install and cutting 7 holes in the interior is all that's left. Pics to come following the install......
Just finished up....
Ordering the xaudiocovers billet grills for the JL's on Monday to match the existing speakers.
Added 3rd set of components behind the front bolsters.
Cut out all 3 holes for the Wet Sounds 10FA's. There was an existing hole, but it wasn't big enough.
Added the stereo battery charger/maintainer in the galley below the built-in cooler.
Stereo battery located under the cabin door
Added an isolator so the stereo battery is isolated from the main boat batteries while the engines aren't running.
Amprack bolted into the OEM amp location. A Wet Sounds Syn1 was used for the 3 subs, and a Syn4 was used for the 3 sets of JL Audio components. Fuseholders and distribution blocks are also located on the amprack.
The hole I had to crawl into to mount everything. Talk about anti-theft options....
Charger plugs into the galley receptacle and charges battery until it's at 100%, then charger shuts off completely. It's by chance that Hustler set that receptacle up so that the shore power plug can be plugged in and powered on, but nothing else on the boat is powered. It actually will work out great.
More pics.
More pics.
