any plans for a v8 gm type engine?
Diamond Member #001
Good old Google. These are from the MasterCraft blog.
5.7 Ski boat package with ZF transmission. Note the proprietary intake system and catalytic converters integrated into the exhaust manifolds.
There more than "a few" of them lined up on the paint line. Apparently, there are also both raw-water and closed-cooled versions.
LS motors are lame!
If they would build some marinized Hemi's based on the new Ray Barton designed World Product produced Mopar Hemi blocks THEN Ilmor would really have something exciting!
http://www.raybarton.com/new_block.htm
Diamond Member #001
LS motors are lame!
If you want to go for big power, marinizing the Ray Barton package would give you something unique and very expensive, but with all sort of custom-made marinization parts. Doesn't seem worth the effort, when there are tons of Chevy-based platforms out there, or even the new quad-cam Mercury 1350's and 1100's. Those are truly sophisticated engines.
Diamond Member #001
What's the largest displacement "generally available" LS engine? The 505 hp LS7? It's not listed as a Marine engine; wonder how much work it would take. Who else is playing with marinized LS engines?
It's doable but it's alot customize work the first time after that you know what to do !
