Code reader for 625's
what is available to read codes on the 625 series? Do they have sensors similar to the smartcraft?
I currently have the Rinda software and it shows compatibility only on the newer stuff. just curious what was available for the older ones?
Scan tool..
The older Ilmor's used the automotive electronics, use your OBD II Scanner to read DTC's. The only thing you cannot get is hours of operation as that was not an automotive parameter..
