Magnum Sport Restoration Begins!
#31
I pulled the motors out tonight, I will tear them down over the weekend and see what kind of surprises are inside! I am going to get started on re-installing the cockpit floor and had a few questions for you guys. Would you recommend using all marine grade plywood or will standard plywood coated in resin get the job done? I am sure this next question will be very controversial but i have to ask........ I am thinking of dropping the floor a few inches and was curious if it would be detrimental to the strength of the hull if I trim the 3 stringers down a bit i would then either add additional stringers or ad structure to the current ones? I have looked through some past threads and am not crazy about the look of dropping recessed boxes down in the floor, I will most likely leave it stock but wanted to get some of your input prior to moving forward. I will post some more pics over the weekend.
#32
If you seal out all the edges & glass underside & face, there's no reason to spend double on marine grade........I've used exterior grade ply w/one smooth from home depot.
I've not completed the cockpit sole yet, but it will be lowered by 7" when I'm done. to visualize this would be as if a "tub" would be lowered into place surrounded by glassed in gussets.
#33
Ironhead lowered his floor when he restored the ANACONDA Mag. It's not a bad way to go if want more freeboard.
QUOTE=hotrod62;3517053]I pulled the motors out tonight, I will tear them down over the weekend and see what kind of surprises are inside! I am going to get started on re-installing the cockpit floor and had a few questions for you guys. Would you recommend using all marine grade plywood or will standard plywood coated in resin get the job done? I am sure this next question will be very controversial but i have to ask........ I am thinking of dropping the floor a few inches and was curious if it would be detrimental to the strength of the hull if I trim the 3 stringers down a bit i would then either add additional stringers or ad structure to the current ones? I have looked through some past threads and am not crazy about the look of dropping recessed boxes down in the floor, I will most likely leave it stock but wanted to get some of your input prior to moving forward. I will post some more pics over the weekend.[/QUOTE]
#36
I like the look of the TRS hatch on the sport. Anaconda & Kemosabe John's 27 both have it. also the best colors in my opinnion....Tangarine & yellow respectively..........Mark, is there any further info on ironhead process to lower Anaconda floor. How many inches?.......full cockpit?
#37
#38
Ironhead,
In my opinnion there is no better looking boat then the 27 sport.....Anaconda is a high water mark among sports... hard to believe (some 40+ yrs. later) the 27 hull & deck design continues to be as timeless as ever.
The only issue I have is low freeboard. The gunnel (or sides)can almost feel equal to the knee's, a bit scary at speed. Like Hotrod62 stated, I to was concerned about structural integrity as well to the hull.. Lowering the floor would certainly help make the family feel more "in" the boat & safe............your family does look to be enjoying themselfs. Was there a feeling of more in the boat after you lowered the floor?....I also intend to have the V meet the hard chime............Wonder if did you document the work?........................and don't worry about the hair thing, it's an "old skool" trait we all share.
#39
Ironhead,
When I dropped the floor on the "Plum Crazy"Sport,
I did not cut down the two side stringers, I only cut down the center stringer and then laminated/glassed 3/4" marine ply wood on both sides of the center sringer. I dropped the floor about 7 inches. I mated my dropped floor against the two side stringers. With the 3 man race set up , I didn't feel comfortable with some one straddling the center stringer.
Back then, Bilt-Rite in Miami built me a new 3 man racing bolster with drop seats on the two outter positions, they wouldn't built it with 3 drop seats as they told me there was was no place for the center position bottom to swing down to.
Thank you
Jim
#40
Jim,
What kind of engine hatch was on Plum Crazy?....it's hard to tell from your avatar. Anyway, I just got done fabricating a "flat" engine hatch & also installed a flush lifting handle by Perko. As far as the floor goes.... 7" was removed from the center stringer which eliminates the side stringers alltogether for maximun space............Parnell has devised a pretty good structual plan.
