Go Back   Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 04-21-2005, 05:48 PM   #1
Baja 322 - Twin 540's
D.U.I. Ignition package $519.00
Triad Performance Marine, LLC has put together a great D.U.I. ignition package for the summer...This package includes: D.U.I.’s Marine Distributor, Rev. Limiter, and LiveWire plug wires.
Suggested Retail $568.00
[SIZE=3]Sale Price: $519.00[/SIZE]
The Performance version is designed for up to 7000 rpms
Performance Distributor's one-piece ignition systems for Marine applications are virtually waterproof. The electronic Dyna-Module and the 50,000 volt coil are built inside the distributor, protecting them from moisture and the severe vibrations that marine engines must withstand. The Marine DUI is an easy drop-in unit that requires only one hot wire for hookup. Other performance ignitions require an array of messy wiring which is always suspect to the hazards of boating.
We recommend you run a wider plug gap with DUI ignitions. Performance Distributor's coils and modules produce a much hotter spark providing a more powerful burn of the fuel mixture by opening up the plug gap to .055".
Every distributor is calibrated on a distributor machine that will give you the instant throttle response that other off-the-shelf distributors will not provide. A very smooth advance curve is dialed in, whether it be for performance cruising or all out racing.
Our marine distributors are blueprinted. Each one is polished, lubed and checked for exact tolerances as they are assembled. Flame arrestors are installed on each housing.
Protect your engine from over revving with the DUI Rev Limiter. The D.U.I. Rev Limiter drops one cylinder at a time very smoothly. This prevents fuel from loading up on the plugs. This also avoids backfires and engine damage. Set your RPM limit with plug-in modules. A 5000, 5200 and 5500 RPM module is included with the rev limiter. Other RPM increment modules are available separately if needed.
Click on the link to find out more about D.U.I.’s LiveWires & options. http://www.tpmarine.com/index.asp?Pa...ROD&ProdID=679
tpmarine.com is offline   Reply With Quote
Old 05-17-2005, 12:05 PM   #2
Re: D.U.I. Ignition package $519.00
This Sale will be ending at the end of the month.
https://secure-checkout58.monstercom...S&Category=196
Thanks,
Don B.
Sponsored Links
Old 05-31-2005, 09:57 AM   #3
Leathl_WS6's Avatar
1997 36 Apache Warrior
How much for just the distributor? Will it work with the MSD rev limiters?
Leathl_WS6 is offline   Reply With Quote
Old 05-31-2005, 08:06 PM   #4
I list the distributors for $305, but with your OSO discount the price is $289.75.
Unfortunately it will not work with the MSD rev. limiter.
Thanks,
Don B.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
what is a boss package? Chain Runner Baja 4 12-10-2007 10:25 AM
525sc package 357sr1man General Boating Discussion 37 08-01-2007 01:14 AM
Raylar Package Nordicflame General Q & A 1 12-02-2004 11:53 PM
Search Engine Optimization by vBSEO 3.2.0
