Super Duty Oil Pans
Old 05-26-2006, 06:26 PM
Only the Best Will Do!
KEPP's Avatar
Default Super Duty Oil Pans
KEITH EICKERT
Wet Sump Hi-Capacity Pro-Series Aluminum Oil Pan
For over two decades, Keith Eickert has manufactured the finest quality marine aluminum oil pans available anywhere. When you hang your name on a product for its reliability and quality, it had better deliver. And deliver is what these pans do. Lets start with the sealing advantage of a cast aluminum pan the C.N.C machined pan rails provide not only the advantage of a perfectly flat sealing surface but also the strength of a pan rail that provides equally distributed gasket load across the entire surface something even the best steel oil pans can only strive to achieve. Each oil pan features an 8 ½” depth sump and will accommodate a 4 1/2” stroke without modifications. Additional stroke length can be accommodated with minor clearancing. Do to the cast aluminum construction rust and cracked welds found in other style pans are virtually non-existent. However, performance is the real reason professional engine builders everywhere choose the Keith Eickert aluminum pans. The iridited full-length windage tray provides maximum rotational crankshaft windage control producing more horsepower than all other comparable designs, while the aluminum construction of this pan acts like a heat sink absorbing heat away from the engines oiling system.
755-8130 B/B Chevy Mark IV Oil Pan Kit
755-8121 B/B Chevy Mark IV Oil Pan Only
755-8122 B/B Chevy Gen 5/6 Oil Pan Kit
755-8131 B/B Chevy Gen 5/6 Oil Pan Only
KEPP is offline
Buddy OO
5
10-20-2007 08:41 PM
Shane B
4
12-05-2006 11:37 AM
ttb
03-15-2004 08:43 AM
Quick Reply: Super Duty Oil Pans
