Go Back   Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-21-2008, 09:33 AM   #1
Offshoreonly Advertiser
DiamondPerformance's Avatar
ITS Extention Box 5" Spacer
Want more set back from your ITS? Now you can!! Five inch adjustable (two inches) Billit Spacer improves acceleration,more stable at top speed,better angle of attack while spanning the waves. Our test boat normally ran 96 MPH with the standard ITS Sterndrive. After we installed the 5" set back plate, increased pitch, our test boat ran 102MPH! 5 MPH FASTER. Kit includes all hardware,CALL 302-521-0123
Diamond Performance
www.diamondperformanceparts.com
diamondperformance@verizon.net
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline   Reply With Quote
Old 10-03-2008, 11:10 PM   #2
2112's Avatar
04' Gladiator powered by Ford
Weight?
Large enough to cover stock footprint?
Uses stock inside transom plate?
Studs, S.S. or ARP Stainless?
Input shaft; 5 inches longer? how? Billet, welded (hope not) etc.
Does it come painted?
Does the stock unit use the O-Ring too? Do you include 2?
Pitch change; How much, how many blades?
Cost?
Thanks, Very interesting, How did you come up with 5 inches?
2112 is offline   Reply With Quote
Sponsored Links
Old 10-08-2008, 08:46 AM   #3
Large enough to cover stock footprint? - YES
Uses stock inside transom plate? - YES
Studs, S.S. or ARP Stainless? - Stainless
Input shaft; 5 inches longer? how? Billet, welded. - Shaft is Stainless, Slides over your Splind Bravo Shaft
Does it come painted? - It is Billet, Powercoated
How did you come up with 5 inches? - The Merc ITS is seven inches, Most Boxes are 12" or 13"inches so we made it 5" inches.
302-521-0123
Old 10-08-2008, 04:29 PM   #4
2112's Avatar
Weight?
O-rings?
Pitch jump, blade#?
Cost?
Old 10-08-2008, 04:30 PM   #5
2112's Avatar
oh and do you have a picture of the input shaft extender?
Stainless? would gear strength steel be better?
Old 10-08-2008, 04:49 PM   #6
Quote:
Originally Posted by 2112 View Post
Weight?
O-rings?
Pitch jump, blade#?
Cost?
Don't know how much it weighs, never had it on a scale. It does come with O-Rings.
Pitch jump depends on how high you set the Box, The Box can adjust up or down 2"inches.
Cost is $4850.00
302-521-0123
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
extention box dummy General Q & A 0 10-30-2008 01:36 PM
extention box on 26NSX outlaw26 American Offshore 0 10-17-2008 02:56 PM
extention box on 242ls VA502t-bird Formula 4 06-04-2007 08:03 PM
extention box bearpaw General Q & A 2 05-19-2003 09:38 PM
Anyone looking for a single extention box ? 26scarab General Q & A 0 03-12-2002 05:21 PM
Search Engine Optimization by vBSEO 3.2.0
