Go Back   Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-13-2009, 04:12 PM   #1
Offshoreonly Advertiser
Mbam's Avatar
1972 Cigarette 36 race
Bravo red-dot gimbal bearings 862540A3
We have a bunch that came out of damaged transom assemblies, they are new never used. I just put them on Ebay for $34.95 each.
http://cgi.ebay.com/ebaymotors/ws/eB...CA:MOTORS:1123
Doing some spring cleaning around here, more stuff soon!!
Marc
www.mercruiserparts.com
www.go-fast.com
and coming soon - www.BamBoatGear.com
Mbam is offline   Reply With Quote
Old 05-13-2009, 06:58 PM   #2
Mbam's Avatar
Ebay busted me, I had a link to our web site in the listing.
New auction is:
Marc
www.go-fast.com
Sponsored Links
Old 05-14-2009, 01:25 AM   #3
Wired Nuts
Jim Diesel's Avatar
03 Sonic 31SS w/500 EFI's
Just bought two, Thanks...
Jim Diesel is offline   Reply With Quote
Old 05-16-2009, 12:40 PM   #4
1BIGJIM's Avatar
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Pachanga-27 Twin 502s
Just bought two myself
1BIGJIM is online now   Reply With Quote
Old 05-18-2009, 10:53 AM   #5
Elite Marine's Avatar
Are these complete with the tolerence ring?
I'm also looking for a bellows kit with the shift cable bellows and necessary hardware. Do I have to order everything individually or whats the kit part number?
Thanks!!
Elite Marine is offline   Reply With Quote
Old 05-18-2009, 11:09 AM   #6
Mbam's Avatar
Yes, complete with ring.
Do you want just the shift cable bellows? PN is 74639A2 comes with the clamps
Or the entire repair kit? Exhaust, u joint & shift bellows along with water hose & gimbal bearing PN 803100T1
If you want to order the bearing directly use our site and order with the standard PN 862540A3 - just put a note on the order to send the Ebay bearing and we will adjust the price.
http://www.mercruiserparts.com/partsByNumber.asp
Marc
www.go-fast.com
Old 05-25-2009, 08:19 PM   #7
ROTAX454's Avatar
1998 Awesome 31 Thundercat
Correct me if I am wrong. Does not the Merc Bravo service manual state that the gimbal bearing would be damaged if removed, so new replacement is necessary?
The service kit number given to Elite is for early (1998) Bravo one drives too?
ROTAX454 is offline   Reply With Quote
Old 05-25-2009, 08:23 PM   #8
2000 Cigarette Mystique
i'll take 2, i dont have ebay though, can i send you a check
Boomer35 is online now   Reply With Quote
Old 05-26-2009, 08:36 PM   #9
Mbam's Avatar
Rotax,
Yes, the bearing MAY be damaged if removed incorrectly. The only way to pull the bearing is to grab it by the inside race which is not a great idea as the force is transmitted through the balls to the outer race. This can imprint the races. However from a practical standpoint this is only a possible issue if using a slide hammer, and even then you really have to whale on it to cause a problem. It is not an issue if you use a threaded rod & plate to pull nice and even.
Same thing to install, do not beat on the inner race, use a driver that pushes on the outer race.
Yes - same kit for all the Bravo's
Boomer - I'm not sure if we have any left, I'll take a look in the AM.
Marc
www.go-fast.com
Old 05-26-2009, 09:41 PM   #10
Got mine today Marc!!
Thanks,
Kirk
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
