Go Back  Offshoreonly.com > Owners Forum > Nordic
those damn warning horns >
Old 08-31-2006, 04:08 PM
Default Re: those damn warning horns
Got the boat back today...dlr said a bunch of Mercruiser's got out of the factory with a couple wires in the harness...switched them and bingo...haven't river tested it yet...goin camping this weekend...hope it is fixed!! thanks for all your input...i'll keep you updated! Greg
Flashr is offline
Old 09-01-2006, 12:30 PM
TSPM's Avatar
Yup....had one here.
About 300 motors were affected.
Mercury changed the 10 pin harness to a 14 pin harness and the Mercury designers reversed two wires in the new design. This fault has also caused the ECM to go bad about an hour or so after the wire fix is done. SO......keep your fingers crossed. Mercury had to send us a new ECM and a few other sensors that got boned up as a chain reaction to the wire harness screw up.
GOOD LUCK....keep us posted
TSPM is offline
Old 09-01-2006, 12:50 PM
I Hope Not...going Camping This Weekend. The Last Thing I Need Is A Broken Boat!
I'll Keep You Posted!
Flashr is offline
Old 09-01-2006, 12:59 PM
TSPM's Avatar
You can call Mercruiser and have them run your Motor Serial number.
They will tell you if it was one of the recalled motors or not.
That might give you some insight on what will be in your future.
TSPM is offline
Old 09-05-2006, 07:47 PM
Got Back Last Night...everything Went Perfect...no Problems At All...put Almost 13 Hours On Her And No Problems....must Not Have Been On Of The Affected Motors...thanks!
Flashr is offline
Audiofn
12-01-2008 09:47 AM
Expensive Date
04-28-2008 10:53 PM
Raypanic
09-26-2005 07:09 PM
wwwTOPDJcom
02-07-2003 05:25 PM
Quick Reply: those damn warning horns
