Nordic Heat - 600sci motor upgrades
We found the 5 blades at standard drive height tend to get a little (or a lot) squirrley at over 90. 30 and 32 Bravos are rock solid at 94-100mph. This particular Heat also hated the spacer.
Go figure
I've come to the conclusion that no two Heats are a like
Also you should be able to eliminate chine walk with props and spacers. Tabs would only be a luxury on this particular Heat. I say that because there was never a hint of even remotely needing them.
Chris,
give me a call at the office tomorrow.
Thanks,
Dave
Go figure
Chris,
Thanks,
Dave
Chris
Dave,
Thanks, I will give a call tommorow.
I only have the one number, and I left a message for you on it earlier this evening, before I got home and read your e-mail.
Thank you again.
Chris
206-235-4545
Thank you again.
Chris
206-235-4545
Chris
I kind of like things clean and simple looking. The word classy comes to mind.
Having it haul ass isnt a bad thing either.
Chris
Chris
Chris
Tim,
Not a problem...
I will just trade you straight across for that big, fast, 34 ft thing you have sitting in your shop.
Chris
Not a problem...
Chris
Chris
Steve,
Thanks for the suggestions.
Have you ever tried "no spacer" with your IMCO lower?
With a Bravo prop?
With a P5x ?
Or did you just try the no spacer thing when you had the Merc lower?
I ask, because I have found that the IMCO lower is faster and more efficient (less prop slip) than the Merc lower on our boats.
Chris
With a Bravo prop?
With a P5x ?
Chris
Steve,
With a Bravo prop?
With a P5x ?
Chris
With a Bravo prop?
With a P5x ?
Chris
Slip in the high teens (Imco lower) to 20% (stock XR lower) with Bravos and no spacer. Never worked regardless of prop mods, like more cup to lock them up, midrange inefficient.
The P-5X did work fairly well with no spacer (Imco lower), @ stock X dimension. Never ran it with the XR gearcase.
Interestingly, it (the 5 blade) still seemed happy with the spacer (13% slip), so I left it in so I could run 4 blades too. Excellent acelleration, lift, midrange efficiency, not weight sensitive, good top end (93 @ 6000 best with your 28") and handling.
With a very tired motor at the end of last season, it ran 91 @ 5900 with your 28" P5-X, and 91 @ 5650 with a stock 29" P5-X. I'm looking forward to testing my T/U blueprinted 29" P-5X with a fresh motor this spring. I'm also going to test some Bravos and 4 blade Hydros. Will keep you guys posted as I get some results......
Regards,
Steve
