There was a manual hatch release made by (I think) one of the west coast custom hardware manufacturers.
It consisted a pin used to preplace the upper actuator to hatch bracket bolt. It had a T handle attached by a wire cable to the pin, with a mounting bracket for the T handle. The T handle would be mounted so it could be accessed to pull the pin in case of acutator or power failure.
Seems like it was made by Eddie or Rex, but I checked their websites and couldn't find it. Teague has a T handle pin with a quick release, but I don't see how you could get under the hatch with his to push the quick release.
Found a similar pin part #620-920022 on Keith Eickert's website for 19.99. Neither of these are the complete kit I had seen, but I have an idea. If they were used for the lower actuator bolt, instead of the upper, they might be accessable by removing the starboard battery.
Regards,
Steve
In boost we trust..............
