Steering Wheel Upgrade
Location: Lakeway, TX (Austin/Lake Travis) / LOTO Gravois Arm
Anyone done this for a Heat?
Does anyone know what the bolt pattern/dimensions are -- in technical terms -- so I know which wheel to get (to bolt-on), or for an adaptor if I need one?
Much appreciated if someone has that info.
I2D
I2D
Regards,
Steve
Thanks, Steve. That's what I thought it would be, but when I removed the center cap from the wheel, is a 5-hole (star pattern). I have not seen an aftermarket wheel offered in 5-hole. Only 6. So I'll probably need some type of 5-to-6 wheel adaptor.
A hub adapter would work fine, or there are plenty of automotive aftermarket 5 hole steering wheels. You could take yours off and hit a local speed shop and match them up.
