HELP Heat power cabin door
Door is stuck closed, hatch is locked. All advice greatly appreciated. Motor is trying to open but some kind of mechanical bind not allowing the door to move more than 1/2 inch.
Ray
Ray
been there, done that. Had the same issue with my flame, something fell on the switch in the cabin, and pressing the outside button caused it to trip the breaker. The breakers are in the cabin, so that does not help.
Had to have the latch lock on the bow latch drilled out.
Another big issue is the engine latch actuators do not work when the battery is dead, and the battery is in the engine compartment. had this issue many times in both the heat, and flame.
The fuse was an issue in the past. My daugher was inside the cabin playing with the door switch and I was opening it from the outside at the same time. Blew the fuse with her locked inside. She was able to climb through the hatch. I relocated the fuse so it could be reached through the drivers side cup holder.
I have power to the motor, so that's not the problem.
It's a mechanical bind of some sort. I guess I'll have to get the hatch opened and climb in.
Something may have fallen out of the backside of the dash, like a bolt/nut/etc, into the lower track, causing it to bind.
That's a tough one Ray.....
I would call the factory and see if they have any ideas.
Good luck,
Steve
Good luck,
Steve
Let's just say that getting into the cabin was the easy part.
The hatch latches were easily turned from top side.
As it turns out, the rail/guides that the door slides on overextended and the slide guide came off the rail. This happened because a stopper came off. It looks as if it were tack welded in place. What a pain in the butt to access this stuff. I guess the folks at Nordic didn't think it would ever break. WRONG! More access should be given for stuff like this. I'm thinking that a removeable panel would work well if it were placed in front of the drivers seat under the helm. Or even making the panel behind the dash larger. Just a thought. The door is still not 100%. I still need to get the bolt/nut that attaches the door to the slide/guide in place. I can't get the nut to catch on the bolt. It's in a real crappy hard to get at location.
