Go Back  Offshoreonly.com > Owners Forum > Nordic
nordic heat transom water pickup >
Old 02-18-2015, 11:51 PM
I've got a bunch of Whipple pullies too if u need a diff size
nedpoole is offline
Old 02-18-2015, 11:55 PM
Ther is plenty of room i see wher did u mount strainer
mach 1 2450 is offline
Old 02-19-2015, 12:13 AM
Engine strainer on transom above fuel switch, intercooler strainer behind battery even w top of stringer. Both are teague u-turn style
nedpoole is offline
Old 02-19-2015, 12:19 AM
Looks great
Old 02-19-2015, 12:35 AM
Also if u can't tell from the pics, the pickup is installed perpendicular to the deadrise angle so the fitting comes out on the engine side of the stringer
nedpoole is offline
Old 02-19-2015, 01:13 AM
Yes i did notice is pickup flush with hull or does it stick down a bit
Old 02-19-2015, 01:15 AM
Flush. Use a ruler to be sure its completely flush since the transom angle is not 90* and the pickup sticks out a bit from the transom
nedpoole is offline
Old 02-19-2015, 01:18 AM
Thats ateague adjustable what do u think about the curved non adjustable
Old 02-19-2015, 01:21 AM
Also noticed your fuel regulator is that directly into the whipple
Old 02-20-2015, 09:41 PM
My pickup is from cp performance. The non adjustable would be fine as long as u get it perfect the first time.
Yes, my regulator is mounted to the rail
nedpoole is offline
