the deleware
#131
Bill, you guys have a safe run, post Mark up on the bow as a lookout and keep it under 60. hopefully before the end of the year we can all meet up at tully cove or somewhere for a last run. I have not run into anyone yet other than you and Mark
#132
RIPSTA Racing Team
Rock the Bay run turned out to be a good time. Friday and Saturday it rained during the overnight hours and each morning started out cloudy but by noon each day the sun came out and we had a great time. The water had alot of crap in it on Friday, Sat it was better with CRAZY fog until noon or so then the run went off with a modified route but it was all good.
Demag, it was nice to meet you and your wife, hope to see you on the 18th at the Bordentown sandbar. Let me know a specific time if you can. I don't know if I'll have my boat. I'll look into the popping tomorrow.
jln, too bad you couldn't make the run. this weekend will probly be my last for the season? We'll see, drives are coming off and being sold. Time for SCX's, no more weak links. Maybe you can make it up on the 18th?
#133
low tide is at 2:10 so i will be up there around 10:30 to 11:00 for the 18th. we had a great time down on the chesapeake. thanks for inviting us out to dinner. hopefully you can get out for one more time this year.
#134
Bill , good to hear you made out ok , friday night i went to the riverwalk in deptford , its right on the delaware . there were so many large logs and debris in the water. hopefully it clears out soon. i know Mark said he had another run or two before season ends . hopefully i can make the next outing.
#135
RIPSTA Racing Team
Well I guess I should have borrowed that allen wrench from you afterall. There was some moisture in the cap, cleared it out and seems to be fine, what a lazy AZZ I am. We'll be out Sunday and check it for sure under load but on the hose, no issues. Now if the weather will just give us a break?
#137
hopefully i will be running a little faster if i can find a set of 26 or 28 pitch bravos or hydromotives. i thought i was running to high but i found out when i am calculating my prop slip numbers i was using wrong gear ratio. gonna try my 26 choppers but not too sure about them.
