Join Us At IBEX
We will be exhibiting at the 2011 IBEX show, October 17-19, 2011 in Louisville, Kentucky. Booth# 1226
Check out our award winning displays and see the quality and options Livorsi Marine can offer your business. For over 24 years Livorsi has supplied gauges, controls and accessories to the high performance, work boat, commercial and government boats.
Its no wonder Livorsi has become standard equipment in major performance boat builders including Baja, Cigarette, Donzi, Formula, Nor-Tech, Skater and Fountain among many others. Below is just a preview of what Livorsi has to offer.
NEW! Electronic Side Mount Ski Control
Two versions of the side mount have been created to fit a wide range of applications: Full Electronic Throttle-Shift and a Hybrid Electronic Throttle-Mechanical Shift. These new ski controls allow for a smooth and safe ride with lightning fast shifting and throttling at your fingertips. Both controls feature dual redundancy potts that are fully programmable, allowing you customize the amount of throttle throw throughout the entire range. Read more…
Vantage View®
Vantage View® instruments display real-time performance data and compiles the information into one gauge- the Master Tach. This tachometer features an analog RPM readout with a built-in LCD screen that displays all the information your engine’s ECM provides. Vantage View® is designed to work with any SmartCraft®, NMEA 2000®, J1939 or GM MEFI engine. Read more…
NEW! The Raw Water Flow System
Safe guard your cooling system from costly damage with Livorsi’s Raw Water Flow System. The water flow gauge indicates your engine’s water flow volume, if the volume is too low, the built-in LED light and audible alarm warns you of a potential danger that would otherwise not be indicated by a water pressure gauge alone. This system was developed to help prevent cosmetic and structural damage to expensive exhaust headers, intercoolers and other cooling systems. We are so excited about this new gauge, that we have submitted the Raw Water Flow System for a chance to win the IBEX 2011 Innovation Award. Read more…
Livorsi SmartCraft® DTS Controls
Livorsi SmartCraft® DTS controls provide consistent precise control of your boat using SmartCraft® DTS technology, which enables smooth and safe shifting. Direct drive of throttle position sensors results in faster response times giving you complete control of your boat. These controls are designed to work on all Mercury I/O, OB and Cummins DTS compatible engines. Several colors and configurations available. Read more…
Schedule an Appointment
If you are attending the IBEX Show or the International Workboat Show, and would like to schedule an appointment, please contact Mike Livorsi by sending an email to: [email protected]
