Livorsi Marine - Upgrade To A New GPS Speedometer Kit
http://i1225.photobucket.com/albums/...s1/livorsi.png
Livorsi GPS Speedometers are driven by a GPS antenna for accurate reading and reliability. GPS Speedometers are available in standard or over sized cutouts with several color options. Our updated GPS antenna models are now built with out a battery and with the ability to be mounted underneath the dash. This means you no longer need to have a awkward looking piece disrupting the look of your beautiful dash. Best of all there is no calibration required. Antennas are NMEA 0183 compliant which means you can use these with any display that accepts a NMEA 0183 input. Mega and Race Series GPS Speedometers Mega and Race Series GPS Speedometers are available in standard or oversize with 5 dial options, several rim colors and two rim styles to choose from. • Kit includes: • GPS speedometer • antenna - NMEA0183 compliant • memory recall switch • harness Mega and Race GPS Ski Speedometer Mega and Race GPS Ski Speedometer is available in standard or oversize cutout. This gauge features an expanded scale from 10 to 40 MPH. 5 dial options, several rim colors and two rim styles to choose from • Kit includes: • GPS speedometer • antenna - NMEA0183 compliant • memory recall switch • harness GPS Speedometers with Odometer This standalone GPS Speedometers with Odometer is a digital gauge driven by a GPS antenna with a 10X update. Combines both analog and digital readouts in one gauge. Built in odometer helps you determine your GPM. For a complete list of options, please visit the GPS Speedometers with Odometer web page GPS Pulse Antenna (Automotive) Converts any brand electronic speedometer into a GPS driven speedometer. For use with existing automotive or commercial electric speedos (Non -GPS speedo heads) Fast 10 Hz 10x update -8/16 pulse output with 4 ft harness and ring terminals to connect to threaded #8/32 studs Part Number: GPSESQ3 |
